Results 1 to 2 of 2
Thread: Above 5K..I feel a mild vibration
    joelrkaplan
    Guest
    Hello every1...in my never ending initial learning phase on my 70T, I have become more comfortable pushing it slightly......when revving over 5k in second and third I notice a mild vibration that seems to be coming from the engine(I feel it most in my seat back)...I realize this could be a little vague to properly diagnose but what should I consider before having a pro check it out....it seems to improve at around 5400k.......stock engine/exhaust w/115k and worn valve guides........
    What immediately jumps to mind is that you center pannel is probably slightly touching the exhaust can/muffle causing vibration at certain RPM. This is extremely common.
    Otherwise, it might be your flywheel being slightly out of whack.
    -Marco
    TLG Auto: Website
  1. 2.2E Mild Upgrade. Short stroke or long? Opinions Please!
    By wagonboy in forum Technical Info
    Last Post: 01-13-2018, 10:24 PM
  2. Vibration driving me mad
    By fran in forum Technical Info
    Last Post: 06-10-2011, 10:34 AM
  3. Mysterious Vibration-Can you Help?
    By guycrosby in forum Technical Info
    Last Post: 07-16-2006, 01:48 PM
  4. 2.2 T engine mild upgrade
    By zaza in forum Technical Info
    Last Post: 05-10-2005, 03:50 AM
  5. Tunnel vibration
    By soterik in forum Technical Info
    Last Post: 04-17-2001, 09:05 AM
