Thread: Alternator Light
    Question Alternator Light
    My alternator light never completely goes out when the car is running (73 S). The belt is tight and the charge is normal. Is the light intensity adjustable? Any ideas?
    1973 911S
    1967 Alfa GTV
    2002 Miata
    If this only happens at idle, I wouldn't worry too much. Do you know the car's voltage output at various rpm readings? This can easily be accomplished by buying a multimeter....
    I found that my regulator was bad. I also removed the alternator and found some damaged wires. It was suggested that I get an internally regulated alternator from a 1974 (I have a 73 with Marchal) Do any of of you have a suggestion and how do I buy-pass the regulator?
    Thanks Phil Guiral
  1. Faint alternator light glow: don't get it
    By Greg D. in forum Technical Info
    Last Post: 05-20-2015, 11:05 PM
  2. alternator light is on, ignition is off
    By noradiator in forum Technical Info
    Last Post: 07-07-2012, 01:15 PM
  3. Alternator ?
    By raspy2point2 in forum Technical Info
    Last Post: 02-26-2009, 09:58 PM
  4. Bosch CDI in '68 911- Alternator light problem?
    By 72tii in forum Technical Info
    Last Post: 06-19-2006, 05:42 AM
  5. alternator light doesn't come on ??
    By typ901 in forum Technical Info
    Last Post: 12-01-2004, 03:20 PM
