Results 1 to 2 of 2
Thread: Early 911S Rookie Needs Torque Specs
    Hello - I'm just completing my first oil change on the '67 911S I bought from Rick Cabell, and notice that page E 125 in my factory manual is blank...that's where the index says the engine torque specs are. #$%^&^(*!!!
    Could someone please provide me specs for the engine / oil Tank drain plugs, and the engine sump cover nuts?
    Also, what's a good source for this info? I'm compulsive about using a toraue wrench!
    Thanks, Bob S.
    Bob Schaefer
    ‘67 911S (Canary / Lemon yellow sunroof coupe w/100l tank on COA & Kardex … 1 of 1 produced??)
    ‘70 914/6 (2.7l RS spec engine, but searching for 6404915 original)
    Goldmember ttweed's Avatar
    La Jolla, CA
    Re: Early 911S Rookie Needs Torque Specs
    Bob-
    Mine is not blank, but the torque spec for those bolts is not there anyway. I believe the two large bolts for the oil drain plugs (the ones with the aluminum crush washers) are torqued to something like 27-32 ft. lbs., just enough to crush the washer and seal. The small bolts which hold the sump plate on are less, about 8-10 ft. lbs. Wayne Dempsey lists 31 and 8 ft. lbs., respectively, in his book.
    HTH,
    TT
    Tom Tweed
    Early S Registry #257
    R Gruppe #232
    PCA National DE Instructor
    Read my surf novel!
  1. Torque Specs
    By 356robo in forum Technical Info
    Last Post: 03-30-2007, 10:56 AM
  2. Throttle Body Torque Specs
    By jayzoll in forum Technical Info
    Last Post: 05-01-2005, 07:35 PM
  3. aluminum lug nut torque specs
    By NiceT in forum Technical Info
    Last Post: 04-27-2005, 03:54 AM
  4. Steel Lug Torque Specs.
    By BradAndersonPHOTOWERKS in forum Technical Info
    Last Post: 01-10-2002, 10:23 AM
