Thread: Ground Wire
    Jul 2011
    Chicago Area
    Ground Wire
    Just bought new '71 Targa and back tail light ground wire was not attached, does this just attach to a bolt on the body? Only bolts I see back there are the ones coming through the bumpers for the deco strips. Thanks
    Mike Fitton # 2071
    2018 911S Carrera White
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    I am not at my car at the moment, but I believe the ground is the bolt holding the bumper corner onto the frame/tub. Look under the bumper corner straight up at the longitudinal line of that corner and you should see a bolt like #42 in this pic.
    1969 S Coupe #761
    Early S Registry #1624
    Right on Bryce!!! it will be the rear most bolt.
  1. Replies: 1
    Last Post: 06-17-2013, 10:37 AM
  2. replica cibies -ground wire issue
    By hoffman912 in forum Technical Info
    Last Post: 07-30-2010, 11:57 AM
  3. Ground wire, rear taillight
    Last Post: 03-18-2007, 10:54 AM
  4. Horn button Ground wire
    By Davz912/911 in forum Technical Info
    Last Post: 10-16-2006, 07:22 AM
