Results 1 to 10 of 12
Thread: 1969 911T questions and new member!
    Jun 2013
    Mill Valley, CA
    Hello all, long time listener first time caller.
    I've been searching for a classic 911 for quite a while now and I found one recently which is a great original car, engine, trans, color and miles, all 189,000 of them at a very reasonable price. I jumped at the opportunity and I am a very proud 911 owner. The car hadn't been sitting idle for a long time but it hadn't been driven on a regular basis either. The previous owner took the car to a Porsche specialist who did a service on the car before I bought it, now I've been driving it around for a week or two loving every minute!
    In the past few days I've noticed the dreaded blue smoke coming from the tail pipe under hard acceleration, oil getting past the piston rings? Time for an engine rebuild? The compression numbers from the service are good from all cylinders and the motor starts / runs fine. Could it be just lack of use? Will they re-seat if I drive more?
    Yesterday when starting off in 1st I got a howling noise from the transmission, no other gear change up or down, just first. It's a 5 speed.
    When I'm in the car driving I hear a buzzing like crickets constantly from the rear which is driving me a little mad?
    Apart from all that she is a beaut and I want to bring her back to full strength and just drive her with a huge grin on my face as I have this past few weeks.
    -Kav. Here are a few pictures:
    Feb 2011
    Henderson NV
    Congratulations! Welcome and stunning color and look! I wish I could help with your questions but do not have the experience myself but will watch with anticipation (as I'm sure you are) for responses from experienced members.
    "The greatest fear in the world is the opinion of others, the moment you are unafraid of the crowd you are no longer a sheep, you become a lion." - @thedailysuccess
    '69 911T (in restoration to be Irish Grn)
    Other rides:
    2008 BMW 328i (wife's car)
    2003 Ford Expdtn Ed Bauer (my daily drvr)
    Welcome Aboard
    Hey, kav . . .
    Welcome aboard
    Nothing beats meeting Those Similarly Afflicted. When you have a chance, try dropping by the Saturday get-togethers at EASY . . .
    http://www.early911sregistry.org/for...June-1-at-EASY
    Jim Breazeale runs the place, + is also on this site. I'm sure he --- and some of the various attendees . . . would have some insights + contacts to help ya out
    And everybody likes light yellow
    HtH
    PS More pictures, please?
    Apr 2004
    35,000 ft
    ignore my answers, most are somewhat tongue in cheek, but I'll try...
    blue smoke, yes, drive it.....as long as you have oil, you won't hurt it....yes, these cars smoke a lot when you drive them if they have been sitting a long time. If compression numbers were all good, you have less to worry about, but top end rebuilds can be needed, too....am thinking valve stems, but who knows.....ALSO, important, check oil level only when car is fully warmed up, and on a flat surface, and with the car running, but at idle.....and check and compare the dipstick versus the oil level gauge.....but always trust the dipstick more, as long as you are warmed up, flat surface and idling. if the car was overfilled, you'll get a lot of blue smoke
    901 gearbox (dogleg....first gear is below reverse, 2-4 is the 'standard H pattern), it is pretty common for first to have a bit of noise, but if it is a lot, you could be ready for a rebuild....nonetheless, if you are gentle on first gear, which you should be, you probably can get a lot more miles out of it.
    #3-call an exterminator, maybe you have crickets? otherwise, is it kind of a squeaky-squeaky noise over slight dips in the road? my first guess is it's torsion bar bushings, but there are lots of cricket noises possible in these cars.
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    Quote Originally Posted by kav View Post
    Welcome, Kav. Looks like a really nice car in an unusual color... Canary or Champagne Yellow? Hard to tell from pics.
    When you say constant and buzzing, I think of the sound of the MFI which is audible in the car at idle. But your car is not MFI if it has the original engine, so... Is this a noise when the car is moving or idling or both?
    1969 S Coupe #761
    Early S Registry #1624
    Jun 2013
    Mill Valley, CA
    The car is Canary Yellow!
    The buzzing is at idle and moving. It is definitely electrical based.
    Thanks!
    -Kav.
    Welcome and Congrats on your purchase. I'm a fellow 1969 911T owner. As longranger suggested please stop by EASY on the first Sat of the month.
    As for the buzzing sound my guess would be the Bosch CDI box located at the drivers side of the engine.
    Jun 2013
    Mill Valley, CA
    Thanks I will check it out. Is it normal to buzz so much you hear it in the car?
    -Kav.
    Kev - I do hear a buzzing sound when at idle but since I have a sport exhaust I don't hear it while driving. Could also be that I'm used to the sound and just don't hear it anymore.
    If you turn you key to last setting before crank mode you should hear that buzz noise which is perfectly normal.
    Btw. Post some interior and engine pics.
  1. 1972 911T front cross member / suspension welding
    By SpawnyWhippet in forum Technical Info
    Last Post: 09-09-2014, 12:47 PM
  2. New Member and project questions
    By BlackC4 in forum Technical Info
    Last Post: 04-23-2011, 09:32 AM
  3. Two questions on a 73.5 911T
    By ralittle2 in forum Technical Info
    Last Post: 09-01-2008, 08:59 PM
  4. New member with questions
    By SDKmann in forum General Info
    Last Post: 12-31-2007, 06:47 PM
  5. A few member questions...
    By Cain DeVore in forum Membership Questions
    Last Post: 11-27-2002, 05:47 PM
