Results 1 to 10 of 10
Thread: Hot air hose question
    Jul 2008
    near Ottawa, ON,canada
    Its for a 68 s
    There is 3 version or the hot air hose in engine bay
    There is the orange rubber
    There is a black paper aluminium version
    And a brown paper aluminum version
    I assume the orange is correct for the exchange to valve location
    But what color is right for the fan to exchanger
    now on the road 914-6
    now in the shop for concourse resto 11850275 S SWT
    daily driver B8 S4 stage 2
    It should be the brown type.
    Incase a pic helps? Here is a 68 motor we built a few years ago.
    Alan
    http://img.photobucket.com/albums/v2...ps6ipud6hl.jpg
    Jul 2008
    Just to confirm this one
    http://www.stoddard.com/90121119401.html
    The originals were usually light tan/brown in the 60s-early 70s then at some point they were a darker brown color. From what I've seen this transition happened around 1975 and the 911SC era cars.
    The black paper covered foil hoses were a later version replacing both brown / tan versions; then as the temperatures rose on the later cars they started using the orange silicone hoses.
    This data is only for the 50 & 60mm main heater hoses; the smaller hoses used for pre-heat systems like MFI were typically black.
    Name:  Porsche 75 S engine hoses.jpg
Size:  69.1 KB original 1975 engine
    Name:  Porscche 29Kmi all original 911T.jpg
Size:  103.2 KB 29K mile 71T engine
    Name:  Porsch 911 OE hose.jpg
Size:  598.6 KB original early SC engine
    Please note these are forum photos I've collected for reference only
    Senior Member beh911's Avatar
    Atlanta
    Quote Originally Posted by aturboman View Post
    The originals were light tan/brown in the 60s-early 70s then at some point they were a darker brown color.
    That is not my experience.
    <20k miles dead nuts original 69S first pic
    "Barn find" 71T in second pic
    1969 S Coupe #761
    Early S Registry #1624
    Quote Originally Posted by beh911 View Post
    +1...agree entirely that these are the correct hoses as shown in the photos for that vintage
    Original 356 heater duct......
    Name:  Porsche 356 blower motor2.jpg
    Original 914 heater hoses
    Name:  914 drain hoses.jpg
    It seems this stuff varied by year and model and what Porsche had on hand at the time
    Also I've noticed on many early cars the tan hoses darken over time and exposure to oil and fuel and take on a very dark appearance.
    Install what you want, I was just lending some perspective on what I've seen over the last 30 years on these cars.
    Jul 2008
    Just to make sure i got both
    Depending on rhe location in the car they do end up slighly different color
    I will have a look at the fine texture
    All the one i have are furry if you look real close
    Will report when i have them
    The other indication is one is a 901 number the other is 930 so definitely later
    Anybody suspect, as i do, that the "orange" hot air tubes started life a much lighter color? I've seen factory photos both B&W and color showing a bone/off white color of all the hoses on 912s and 911s where orange now appears.
